Hi all.
Have a houdini a some ways for creating multicolored (sorri, i don`t know right name for this) volumes for post color-correction ?
Or how professionals make this ? My skill in this is “zero”. But, if for example, i have troubles with lighting in 3D scene setup (or it very long time to render with shadows) - how can i do this trick for post-composition?
And, please, if someone know, where i can read about this ? I`m only see this technique in Digital Domain demos… No learning info.
How can i create this effect in houdini ? This possible ?
p.s.
Sorry, i mean post-lighting setup. Or lighting and color correction of volumetric effect.
Mullticolored volumes for post-color-correct.
4279 5 2- live_fx
- 160 posts
- MiguelPerez
- 41 posts
- live_fx
- 160 posts
- live_fx
- 160 posts
- pbowmar
- 7028 posts
Three lights can be a bit limiting and of course only works if you have monochrome (i.e. grey) volumes.
The more advanced solution to this is to make your own Illuminance loop that breaks out each light to its own deep raster image or channel. There is a thread on Odforce (somewhere) detailing this, though it's not for volumes specifically.
Basically, a Volume shader has two components. One calculates the density of the volume, and the other calculates the lighting on the volume. The density is of course the same for each light, so that is just calculated once. The lighting is calculated for each light. The trick is to make sure you multiple the lighting calculations by the density for each light otherwise it looks completely wrong (blocky and ugly).
Peter B
Peter B
- live_fx
- 160 posts
