Use arc end as a value
2700
3
0
- heydabop
- 203 posts
Is it possible to display the value of the end of an arc of a circle in a text node?
- stevenong
- 1631 posts
You can RMB on the second Arc Angle parameter, select Copy Parameter and RMB on the Text parameter of the Font SOP & select Paste Copied References.
Hope I understood what you're looking for.
Cheers!
steven
- heydabop
- 203 posts
Thanks, sounds like it will work. I'll tell you once I can try it out.
- heydabop
- 203 posts
It worked, thanks. I had the right idea, I was just typing stuff wrong.
