How to make points combine become line?
   3672   2   1
Hi , i make many points as (human spine) with points SOP ( is all with algorithm)
but suddently when I want to used it with sweep SOP I found out that points cannot working fine but only points with line can working fine.
I would like to know how to make the points add a rail from point 0 - 33 .
as it show below PNG image.
or if you can let me know how to make points create a normals refer to the rails of the point I would be also very very very very thank you.
append Add SOP
in Polygons Tab select By Group
OMG thanks , is so easy , i spend 2 hours on this …….
Thanks very very much
