I was going through the forrest asset tutorial and got to the part where you override the color with the pscale and then are supposed to paint the boxes and they should change accordingly. When I do this my boxes just don't change…. just wondering if anyone had any suggestions….
having trouble with the paint surface node....
3889 4 1-
- rdevito
- 2 posts
- オフライン
- edward
- 8094 posts
- オフライン
- rdevito
- 2 posts
- オフライン
- edward
- 8094 posts
- オフライン
- tamte
- 9420 posts
- オフライン
you better change both to lowercase, because “pscale” is automatically recognised by the Copy SOP and the copies are scaled by it accordingly
if you middle click on paint SOP it should say pscale in point attributes
if there is pscale, delete paint SOP and create new one
If you post the .hip file you have so far, we can probably take a look.
