Difference between gas_diffusion and gas_blur microsolver?
   2168   0   0
What is the difference between the gas_diffusion and the gas_blur microsolver?
I was under the impression that they were pretty much the same thing as they seem to be used for a similar purpose.
Inside the pyrosolver in the temp_field_advect1 network box, there is a “diffuse_smoke” that is done using a Gas Blur.
I am making colored smoke and want to diffuse the smoke (so the colors mix) and was wondering if I should use a gas blur or a gas diffuse microsolver.
Thanks for any advice.
