I've just made the leap from H8 to H10 and find that things are in different places.
In H8 there used to be a “ray bounce” for each geometry object. I don't see this in H10. If I add a “rbounce” value to the geo then it either doesn't get send to mantra, or is not used in H10 mantra.
How does one specify a per object ray bounce value in H10?
Thanks,
Robert
Ray Bounce in H10
4210 4 1- RobertP
- 48 posts
- stevenong
- 1631 posts
Hey Robert,
The Reflect & Refract Bounce parameters have been replaced by the Reflect & Refract Limit properties which you have to add to the Object. Also, depending on the shader you use, the properties are already added to the shader so you don't have to add them to the object.
Hope the above helps!
Cheers!
steven
Cheers!
steven
- RobertP
- 48 posts
Thanks Steven!
It works on the object level!
You say it can be done on the shader level? I've tried that and it isn't working. Are you sure it can be done on a shader level? I don't see any “canned” shader from Sidefx that have it, and when I add it there isn't a difference. What's the trick in shaders?
Thanks,
Robert
Thanks,
Robert
Adtech Communications Group
- stevenong
- 1631 posts
- RobertP
- 48 posts
