RDBpointObject s are not able use pscale for ODE objects.
   2417   0   1
has anyone else noted that RDBpointObject s are not able use pscale
for ODE objects.
if you take the example file from the help of the RDBpointObject and
then in the particle_start object you add a random pscale attribute
it will not apply that scale to the ODE geometry.
can anyone work out how to still use the pscale attribute and the ode
bounding box or should this just be avoided and randomly switching
between random sized objects is the work around?
any thoughts?
Robert Kelly
