given an operator name (token) is there a way to
query all possible table definitions that name could
belong to?
ie. > optable my_Asset
Pop/my_Asset
Sop/my_Asset
seems like you need to have a network path of
a node before you can ask questions about its
context. but then, you would already know that!
table name given an operator name
1787 1 1- sdugaro
- 380 posts
- sdugaro
- 380 posts
i guess I could try an opfind and optype on that to the effect of
/ -> opfind -p /obj/fld_FluidSim_Example -t fld_FluidSim
/obj/fld_FluidSim_Example/fld_FluidSim/example_density_with_initial_velocity/fld_FluidSim
/obj/fld_FluidSim_Example/fld_FluidSim/example_collision_object_and_particle_forces/fld_FluidSim
/obj/fld_FluidSim_Example/fld_FluidSim/example_force_field/fld_FluidSim
/obj/fld_FluidSim_Example/fld_FluidSim/example_target_field/fld_FluidSim
/obj/fld_FluidSim_Example/fld_FluidSim/example_attribute_advection/fld_FluidSim
/obj/fld_FluidSim_Example/fld_FluidSim/example_attribute_advection/fld_FluidSim1
/obj/fld_FluidSim_Example/fld_FluidSim/example_attribute_advection/fld_FluidSim2
/ -> optype /obj/fld_FluidSim_Example/fld_FluidSim/example_attribute_advection/fld_FluidSim2
Op Type: fld_FluidSim
Op Type Label: “fld FluidSim (v40 spi)”
Net Type: SOP
Script Directory: sop
Net Type ID: 1
Table Name: Sop
but it would be cool if there was a way to query the operator tables directly.
Net Type: SOP
Net Type ID: 1
Table Name: Sop
