Pointgroups and Foreach
   3415   3   0
Since foreach doesn't work with pointgroups, how would one go about fusing mutiple groups of points separately?
U can fuse multiple pointgroups using a copy sop. Take a look at the attached file. Hope this helps u.
Fusing_pointgroups.hip (58.3 KB)
Thanks Raavenish,
I'm not quite sure I understand what's going on in the file. You've made 3 point groups, then the delete sop references a group that doesn't exist (group_0). The fuse sop then fuses everything that's remaining together.
I'm really looking for a way to fuse/snap each one of those separate groups of points together, so that each group ends up in the averaged position of the points in each group. I can do that by hand one by one, but need a more procedural approach.
After another search of the forums I found the answer:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=18723&highlight=foreach+pointgroup [sidefx.com]
I've attached a file for future reference.
~M
fusing_pointgroups_in_a_foreach_sop.hip (64.9 KB)
