I'm creating geometry on the fly via a VRAY_Procedural, setting
the shader reference on each polygon using the shop_vm_surface attribute. Since that is a reference to a SHOP node, how do I create the SHOP node?
Creating materials in VRAY_Procedural
3097 2 1-
- mercier1
- 2 posts
- オフライン
- mark
- スタッフ
- 2676 posts
- オフライン
mercier1
If you want to apply the same shader to the entier geometry, please look at the box procedural sample code.
Otherwise…
The SHOPs have to be pre-declared in the IFD (you can see the syntax in an IFD that has these embedded – the ray_start material block.
This might not be ideal for a procedural.
Method 1
Fortunately for you, the “old” style of attributes is also still supported (and probably will be for a long long time).
If you add the string attribute “vm_surface”, you can specify a surface shader string explicitly (or vm_displace).
Method 2
Generate multiple sets of geometry instead of trying to do it all at once. Rather than making a detail with shader attributes, why not make multiple geometry objects in mantra without any geometry shaders, but using the surface property instead?
- pclaes
- 257 posts
- オフライン
You might find this interesting too:
http://forums.odforce.net/index.php?/topic/10781-vrayprocedural-and-material [forums.odforce.net]
