Hi there,
I try to figure out if there is a way to non-uniformly scale bones. I need a
Squeeze and Stretch effect on mesh. Or ist there a better way to achive this.
any advice is appreciated,
how to non-uniformly scale bones (Squeeze and Stretch )?
2938 8 1- mickyblue
- 217 posts
- edward
- 7721 posts
- mickyblue
- 217 posts
Thanks Edward!!!
It works somehow….
Are there any rules or good ways to connect all those relationships together?
I used an if expression so far. But I noticed that the expression seems not to work after I reload the hip file, and needs to be reactivated manually. It all seem not to be very robost by now.
Do you have any suggestions on this?
Enclosed a hip file
It works somehow….
Enclosed a hip file
- edward
- 7721 posts
There are some inefficiencies in your .hip file but the main mistake is that you're doing a ch() expression to a point() expression which uses $PT. But $PT only exists during cooking so that can't work. Given your set up, it's simple to just replace $PT with 0 to have it work consistently.
So some of the things which I think can be improved are:
- No need to use AttribPromote from Primitive to Point just to use the point() expression. Instead, just use prim() expression directly. Again use 0 because you only have a single primitive.
- Better yet, don't use SOPs to calculate the distance between two object nodes. You can directly use vlength(vtorigin(“/obj/chain_root1”, “/obj/chain_goal1”)). If you're worried about recalculating it all the time, then you can put it directly into an AttribCreate.
I've attached my modified .hip file by directly using vlength(vtorigin()).
- mickyblue
- 217 posts
Thanks Edward!!!
Everything works great now. The only thing I dont get is why replacing “$PR” with “0”works fine. Does the reading of one prim need no cooking although its still a sop based point() or prim() expression. Why?
It distroys my little logic construction
Cant find that in the documentation.
Thanks Edward.
Thanks Edward.
- edward
- 7721 posts
$PT and $PR are called “local variables”. Local variables like $PT work in the Point SOP like this:
- The SOP cooks
- For each point, the node evaluates the parameter
- When the parameter evaluates and it sees $PT, the current point number is substituted (eg. 0, then 1, then 2, etc.)
In your case, the SOP is *not* cooking at all, the *OBJECT* is cooking. So $PT can't be evaluated.
- The SOP cooks
- mickyblue
- 217 posts
- edward
- 7721 posts
- mickyblue
- 217 posts
