Hello all,
I am emitting fluid from particles, but I was wondering if I can use the same particles to use as a field for the fluid. Is there such a way to emit and affect fluid at the same time? Thank you for reading my post!
using particle as a field in fluid?
4005 3 1-
- jkim7979
- 10 posts
- オフライン
- pclaes
- 257 posts
- オフライン
Sure you can.
Look into the gas_particle_to_field dop microsolver. You can transfer the velocity from the particles (or from points in sops) to a custom field in dops. You can then add that field to your velocity field in dops.
So in a way you are creating a custom velocity field. You might find this interesting for further reading:
http://www.peterclaes.be/tutorials/PeterClaesThesis/index.html [peterclaes.be]
- Erik_JE
- 300 posts
- オフライン
- jkim7979
- 10 posts
- オフライン
