wire object & SOP solver DOP
   1921   1   1
I want to modify an empty wire object during the simulation. So i'm using sop solver to add new geometry to my wireobject. When i'm creating a new wire object (e.g. each frame) and adding my geometry to this new object, all works fine. But when I want to modify existing empty wire object ( add geometry to it), it becomes non dynamic (forces etc can not influence on it).
So here is the file with two dopnets. Green is working, red no.
generate_wire_objects_02.hipnc (235.6 KB)
Solved : to get it work I should add an attribute “mass” in side the sop solver
