I am starting to play with fluids. I wonders how to emit fluid particles from polygons like Realflow splash emitter. For the moment, I can only emit from closed meshes.
Vincent
about the fluid emission ...
6061 5 2-
- vbk!!!
- 383 posts
- オフライン
- Erik_JE
- 300 posts
- オフライン
- ragupasta
- 349 posts
- オフライン
- vbk!!!
- 383 posts
- オフライン
Erik_JE :
In Reaflow the Splash emitter is used with a Realwave mesh.
The Realwave mesh is acting like a ripple solver in Houdini.
It's possible to add splash emitter to the RWave mesh to create fluid particles when an object hit the realwave surface.
In Houdini, I know how to emit particles from a polygone with a POP network.
I would like to know if it's possible to do the same with fluid particles.
ragupasta :
I would like to use SPH or FLIP fluid to add detail to a ocean.
I can do it with POP but I need to obtain viscous liquid behavior and I don't think the POP can help to achieve that.
Vincent
ragupasta :
Vincent
- ragupasta
- 349 posts
- オフライン
- vbk!!!
- 383 posts
- オフライン
