Welcome to test my implementation of shaded beams! It is my first mantra volumetric and first H12 plug-in.
You may use this code/plug-in absolutely free.
Project is placed here [code.google.com], you may build it with hcustom tool - no additional dependencies required.
Thank you!
Shaded beam fx
3194 3 1- JOEMI
- 128 posts
- rdg
- 401 posts
- JOEMI
- 128 posts
There are an article and movie, which describe and demostrate what is it.
In short - this is a mantra volumetric procedural, which may sample a set of 2-point segments and produce a volumetric, enveloping each segment. But you may inject a CVEX procedure, which may alter each segments appearance.
Anything that flies
- JOEMI
- 128 posts
Let's introduce next iteration of this fx mantra plug-in
1. changed amount of computed quantities - lowered to just 1, vector4 Bs
2. changed boundboxes computing scheme - each beam has enveloped with group of cubeshaped boxes
All these improvements significally reduced (by 5-10 times) rendering time and made this solution adequate for practical using. For example - 1Kx1K image of system of 100+ beams with noticeable thickness and sophisticated CVEX shader renders with micropolygonal renderer with ~1h15m user time (divided to 4 threads of my old Quadcore660 - ~20-22m). You may find a scene at download section and compare for yourself.
Thank you!
Thank you!
Anything that flies
