Houdini12 Build 581 - few bugs
   6177   5   1
I recently installed the latetest buid of Houdini12 because in the previous I had this creazy problem http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=25583 [sidefx.com]
but it seems houdini 12 is still very buggy and I am not sure if I should use it in an production. The latest bugs I faced was:
1.in a popnet where particles emitted from surfaces in a random way, the force I used to move them upwards, it was ignored. I had to open houdini again inorder to fix this.
2.in the same scene, suddenly all the “new” created primitives was scaled up in y direction. The old geometry was ok, but anything new was scaled, no matter what. Reopening the scene didn't helped. I had to create a new session and copy paste the objects I want it from the old one.
3.as the particles moving upwards, I have copy sphere as instances and I am using stamp to get random scales, but for some reason the scale comes up and down as the particles moving. I cant fix this no matter what.
Does anyone else had any similar problem with Houdini12 or older versions?
Houdini is an amazing software and 12 is an amazing release, I hope soon we will get a stable build.
got alot of crash problem in here too..
and the help file is not complete…err never complete even some of the old node is undocumented.
the example file doesnt show much of the new features
but im really glad that i got the chance to play with it as it is…
i hate to say it but u guys really need to learn from auto***k on how to make documentation.
best regards
Patar
If you think you have a bug submit a scene file to support after all if your in a production you should have support for your licenses. Its fine to write a list of things you think are wrong or not working but unless you post up a scene file showing those issues for people to look at its all talk.
rob
Gone fishing
btw now that i used 12.0.586 its alot more stable…im guessing the crash were all open gl related (as u may know from the journals lately the open gl part is being revised heavily)
スタッフ
オンライン
There are lots of OpenGL issues being fixed constantly, so use the latest builds wherever possible. Also, try the different OpenGL viewport types (under Edit > Preferences > 3D Viewports) and try using the highest GL version you can (or try different ones when getting viewport bugs), and don't hesitate sending bug reports to SESI! They appreciate all the help they can in tracking down and fixing these things!
I'm o.d.d.
another one, the world seems to be rotated 45degrees right, you can see that by the viewport grid and how the default camera rotates. Once you restart another session everything is ok but I saved the scene this time and you can see it yourself.
Houdini11.0.581, Linux64, Education Edition
new.hipnc (851.7 KB)
