named missmatch attributes
1994 2 2- Follyx
- 237 posts
- neil_math_comp
- 1743 posts
Do you mean on the Merge SOP? I definitely agree clarification could help when it does that.
However, it might be difficult to display which attributes from which inputs are missing in which other inputs when there are many inputs and many attributes. It might be possible to put in just a few bits of info, though, (I don't know). Could you give an example of the sort of text you think would be most helpful, and maybe a hint as to how you'd like it to behave when there are many inputs or attributes?
- Follyx
- 237 posts
ok, I'll do my best:
Yep, the merge SOP
the jpgs are self-explanatory.
As you can see without the attrib-del SOP I've a mismatch of 2 attributes.
It wouldbe perfect if the infobox of the missmatched merge SOP would tell just with the attribute names wich attributes causes the mismatch. In other cases its pretty time consuming in checking and figuting out the missing attributes. In my recommendation it would be much easier: reading the missing attribute names, an del-Attribute SOP, ready.
Cheers
Yep, the merge SOP
Cheers
