hi
is there any thing like creep sop in houdini with more control ?
i need my object be in these form and then fly
little help …. thanks
Creepy
3038 6 3- Hossein_SHA
- 27 posts
- tjeeds
- 339 posts
- Hossein_SHA
- 27 posts
tjeeds
Just use a blend shape to pull it into your animation.
thanks Dear tjeeds but my case so complex than these actually
i have cloth animated and i want to these butterfly to fly from it and cloth
Will be trimmed
diue d'amour
HonersforGod@Gmail.com
HonersforGod@Yahoo.com
http://www.youtube.com/user/SHA3254/videos [youtube.com]
- pelos
- 618 posts
- Hossein_SHA
- 27 posts
pelos
can you do a ray cast combo with a vopsop
you can ray a distance (just get the attribute, dont move the geometry) and with that
saying if the ray distance is more than something put into a group,
and then in that group you can ray it again this time, you can actually deform the geo.
pelos i need vop solution because it's more flexible is there any example for these way you just mentioned ?
diue d'amour
- tjeeds
- 339 posts
The Intersect vop does ray casting and returns prim number and parametric uv, the xyzdist vop does this as well if you don't have a ray direction. Once you have these attributes you can use the Primitive Attribute vop to pull P from the parametric coordinates on your animated cloth.
Jesse Erickson
Fx Animator
WDAS
Fx Animator
WDAS
- Hossein_SHA
- 27 posts
thanks guys … you're awesome
i playing around with ray sop and Intersect vop as you said guys and pretty happy with theme
diue d'amour
