Mantra stop rendering with "high" OceanFX
   2467   1   1
Hi, I've a problem rendering “heavy” Ocean Wave from Ocean FX.
My problem is that while is that if I use resolution above 10 or “high” number for row and column for the grid, Mantra stops rendering.
I think it's a memory related problem, but my task manager says that I'm using less the 10 GB (and I've 32 GB of ram): any suggestion?
are you on Apprentice or Apprentice HD? Because I´ve seen similar behaviour and I suspect it is because the generated displacement map is above HD res.
Javier Meroño
FX TD.
