interface refresh delay
   4047   2   1
hello.
I think that I had changed accidently some feature in interface setup and now I can not find where i can repair it. Any changes made by handles or paramiters tabs (scaling, rotat. trans… anything) display after all… when I drag off handle or leave parameter alone. Quite confusing when you want to play around with your parameter and find good value.
Any solution?
thanks!
symek
スタッフ
It's likely the button in the upper right of the interface which says one of (Always, Changes, Never). You're going to want to click on it until it is back to Always.
o my God!
that was so easy! Funny thing is that I often use this buttom because my vga is very slow…
I dived inside every corner of H. setup… and the answer was right at the front of me and well known.
thanks,
symek.
