Hi
I'm currently doing try&error of FEM solver especially at denting fx.
During looking into nodes partially prepared for cloth fx, I have found Soft Body Plasticity Properties node and I tried it to get result by that way(attached img).
But it seems it's not working.
I've had a look around Soft Body Plasticity Properties [sidefx.com](Although it's been registered in tab menu as this name, help button shows Soft Body Fracture Properties) and tweaked a bit but I don't make it clear enough.
Should I put this node with SOP Solver and import some data into Geoemetry field?
Has anyone used this node?
BTW, I've tried these solutions below to get denting fx:
H13 Masterclass | Finite Elements [sidefx.com]
Houdini 13 - Dent Rigid Body Objects [vimeo.com]
Houdini - Impact deformation for RBDs [vimeo.com]
Thank you.
P.S.
my environment:
OS: Mac
Ver: H14.0.261
How can Soft Body Plasticity Properties be used?
2255 0 0- takanori
- 8 posts
