Hello all,
I would like to change a planes resolution according an image resolution that I'm loading in, in a Cop2Network.
What would be the best solution to read in that info from a image?
Thanks, Robert
reading image size in pixels
4646 5 2- Robert Glotzbach
- 85 posts
- sidenimjay
- 702 posts
in the houdini textport type “exhelp res”
you can use this in your grid xy size, but you need to import the image into a cop network to access the information
float res (string compositing_node, float res_type)
REPLACED BY
hou.CopNode
Returns the natural resolution of the image in a compositing node.
<res_type> is either D_XRES or D_YRES.
EXAMPLES
res(“/img/img1/color1”, D_XRES)
REPLACED BY
hou.CopNode
EXAMPLES
- malexander
- スタッフ
- 5170 posts
- sidenimjay
- 702 posts
- Robert Glotzbach
- 85 posts
Thanks a lot gentlemen for helping,
Again this showed me that I should be more precise with how to formulate a question ;-)
But SideImjay was indeed pretty close.
I would like to change the amount of x and y rows of a grid (actually size too) according to the resolution of an image that I loaded in, in a cop2network.
That way, each time the image gets changed both size and resolution of the grid gets changed accordingly.
I am new to Houdini so I will need to hurt my brains for quite a while beore I will be more comfortable with all this.
Regards, Robert
Regards, Robert
Houdini, Cinema4D, 3Dcoat, Marvelous Designer
- Robert Glotzbach
- 85 posts
