Hi all,
Probably a stupid question - but I'm trying to figure out the VOP networks when it comes to shading and one thing I cannot currently figure out is how the SSS Component VOP is supposed to be used.
I can output the ‘sum’ into Cd of a surface output VOP…is that the correct thing to do? Plus, this only works when using non-PBR renderers. How is thise supposed to be used in that case?
SSS Component - How to use?
1534 2 2- Anti-Distinctlyminty
- 271 posts
- sidenimjay
- 702 posts
- 271 posts
Cool - that makes it function in the PBR. Even though I thought you had to use a BSDF in the PBR.
Are there any resources on the VOP networks when it comes to shading? How to construct shaders from scratch for both PBR and non-PBR renderers. The steps to combine various diffuse, reflection, refraction, etc. components together?
I'm coming from a Lightwave background if that helps at all.
