Houdini not working (hanging) on OSX Yosemite Version 10.10.5
   2999   3   0
Hi all, I've had this software on windows and it has been a wonderful experience. Trying to help a friend of mine set up on his MAC system is proving to be a nightmare.
1-First off, after installing houdini and we trying double-clicking on the houdini icon… nothing happens.
2-Opening up the houdini.shell terminal was successful. However, launching Houdini from there yeilds this result:
File “/Library/Frameworks/Houdini.framework/Versions/13.0.416/Resources/bin/houdini”, line 140, in <module>
main()
File “/Library/Frameworks/Houdini.framework/Versions/13.0.416/Resources/bin/houdini”, line 121, in main
path = check_hfs()
File “/Library/Frameworks/Houdini.framework/Versions/13.0.416/Resources/bin/houdini”, line 48, in check_hfs
path = os.environ
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/UserDict.py”, line 23, in __getitem__
raise KeyError(key)
KeyError: ‘HFS’
I dont know what to try next…
Please help
crash.freelancer_7091_log.txt (3.3 KB)
Have you tried using the latest version of Houdini? It looks like you are installing version H13.
Try posting your Mac hardware specs or review the system requirements.
Houdini 15.5 does not work with most Mac hardware. Especially low-end machines.
Edited by Enivob - 2016年7月8日 09:48:21
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
For serious work don't use a Mac. Even with the latest version 15. Just my 2 cents
I found out the hard way as a novice. It seems there are tons of OpenGL bugs in the viewport for the Mac version of Houdini. Feels almost like beta software.
Now transferring my licenses to a Windows laptop.
I assume many power (Pro) users use Linux boxes
Edited by art3mis - 2016年7月12日 17:19:22
I think there's possibly an issue with H13 on 10.10, H13 is pretty outdated now. You might need a newer version of Houdini.
