Scope channels seems not work
   5600   6   1
When pressing v while a node is selected or when pressing control+rmb > scope channels the channel editor does not open. Do I have to modify a setting in the preferences :?:
I believe it is Shift + MMB
Hey sascha, I think that functionality will only scope the parameters if they already have animation on them.
Shift + MMB is the same as MMB.
The object's channels have animation, one channel has a key and the other one has an expression. If I open the Channel Editor manually and when I click on Scope> and select my selected object both channels appear under Other Parameters.
Isnt Shift + LMB ?
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
scoping is shift + MMB
scope append is shift + LMB
Thanks, v does work now from the network editor. From time to time I have the feeling Houdini is pulling my leg.
