advance cursor to next field?
   2416   2   0
Sorry to ask such a dumb basic question but I cannot seem to find the answer- How do I advance the cursor to next field while entering data in a parameter panel? As in, I've created a box and I enter 2 in the Y field and then want to go to Z without moving my cursor…TAB does not work as it might in a web form so what is the Houdini equivalent?
Edited by Tony Hudson - 2017年8月19日 16:24:19
Houdini 16 & 15.5 Indie Limited-Commercial
Windows 7 64-bit OS i7-6950X 3.00GHz
128 GB RAM 2x GeForce GTX 1080
It should be working like you described.
Side note: I just checked in the hotkeys manager and, weirdly, there's no “action string” related to this particular behavior, so I don't know how you can set its functionality back.
It looks like it's not even an hotkey.
Ok, for anyone else that might be confused, TAB does work.
My problem when entering values in X, Y, and Z was that I would type “4” and then hit the ENTER key and then try to TAB over. If I instead enter “4” and then TAB immediately it will enter value and advance to next field.
Once again, user error. (siggghhhhh)
Edited by Tony Hudson - 2017年8月19日 20:50:44
