the documentation says that, when the match profile checkbox is ticked, the loops position along the curve will be determined by a fixed distance and not a percentage along the curve.
I expected to enter a distance in units, say 5, and the cut will be made at a 5 units distance from the beginning of the curve.
Or 5 units from the end of the curve if switch profile is enabled.
But the result is still a percentage and there is no parameter to enter a distance. the edge percentage and split location fields only accept numbers in range 0-1.
Did i misread this?
Is there another easy way to cut a curve or insert a loop at a specified distance?
I know that i could measure the distance and cut via expression but i was hoping there is a simpler solution.
Thank you very much
polysplit behavior fixed distance
928 2 1- jkrein
- 5 posts
- lfranceschini
- 72 posts
- jkrein
- 5 posts
