Finding and grouping overlapping Points or Verts
   2636   2   1
Hi
I come from a Maya background, using Houdini and trying to find a way to get overlapping Verts/points in houdini. They technically share the same worldspace position.
Its essentially unwelding geometry from Marvelous Designer.
I found the fuse node but that obviously merges the points. I want to be able to store it or keep it as lists and use that data later.
Like points sharing the same world position would look something like this.
(if 4 meshes where overlapping at that point.)
I am mainly using SOP net
Imran
Edited by im_a - 2019年5月28日 13:51:51
In H17.5 you have FuseSOP v2. Turn off “Fuse snapped points” and activate “Snapped points group” option. This will create a group with snapped points. Then you can use a GroupCopy SOP to transfer the newly created group back to the original mesh - before fuse/snapping.
Thanks that worked really well.
