Viewer State noSelection?
   893   1   0
Is there a noSelection event handle or a way to check no selected on scene view? should i use runSelectors from utils.py? or can i call onSelection somewhere else cause when i tried that i got an error: KeyError: ('selection',).
def onMouseEvent(self, kwargs):
    bType = self.onSelection(kwargs) #error: KeyError: ('selection',).
bType = self.node.geometry().selection() #prints out None
I need a way to get a True or False if there is something selected.
found a way that worked for me but dont know if it'll work for anyone else but my solution was:
        """ Process mouse events
        ui_event = kwargs["ui_event"]
        device = ui_event.device()
        origin, direction = ui_event.ray()
        inputs = self.node.inputs()
        reason = ui_event.reason()
        # Only try intersecting geometry if this node has input
        geo_intersector = None
        if inputs and inputs[0]:
             geometry = inputs[0].geometry()
             geo_intersector = su.GeometryIntersector(geometry, scene_viewer=self.scene_viewer)
             isGeo = None
        if geo_intersector:
             isGeo = geo_intersector.intersect(origin, direction)
             position = geo_intersector.position
        if self.bSel == True:
            #Create/move point if LMB is down
            if device.isLeftButton():
                if isGeo == True:
                   self.start()
                   self.setPoint(self.index, position)
            else:
                self.finish()
        elif self.MouseDragAction == True and self.bSel == False:
                   if isGeo == True and self.noSel == True:
                       self.setPointPos(position, self.CurrentPt)
              if reason == hou.uiEventReason.Changed: # <--- when the position is changed or stopped dragging the point isnt
                                                             selected anymore so when the user lets go of left mouse button.
                    self.noSel = False
                    self.CurrentPt = None
              else:
                  self.finish()
        # Must return True to consume the event
        return self.bSel
