Hi Guys.
I'm using Houdini 18 Indie. I've been a houdini user since early 2018. I work mostly with flips and oceans. I've got a couple shots where the ocean and extended is simulated, cached, and rendered with a spaceship in there as collision. Everything's great.
The problem happens when I simulated and rendered white water with the flip fluid extended. If I place the render flags on all three (white water, fluid extended, and fluid interior) Houdini cranks up my ram memory right to the ceiling (64 gb) in no time everytime. I have to esc or cancel so the system doesn't crash. It's weird. When I render the ocean and flip on it's own it works. When I render the white water on it's own it works but when I render them together it runs out of memory and crashes.
Does anyone have any idea why this is or what the work around would be for this? I can try to render them separately and import them into Nuke and composite them together but I think it'll look weird because of the rendered white water bubbles under the surface that will show.
Any ideas? Anyone?
Pierre
Problems rendering ocean extended with white water. Crashes!
639 0 1- PJM33
- 15 posts
