There seems to be an issue where if I set up a render chain where the 3D / camera scenes render to image sequences, then if I read in those same files into a COP chain, and then attach a compositing-render-node downstream of the origional 3D render's, the file-cops don't update until I click on the “reload” button.
It's fine if I hit the reload, but in the case where I want to delete the images or change the image size (which causes the natural resolution to change) I would have to manually wait for my 3D stuff to render before hitting the update button for the 2D stuff.
This is a problem when I have chains and chains of 3D that depends on 2D, any ideas on how to make the file cop's automatically adapt to whatever I give them (as long as they are downstream in the render nodes).
how to update cops on rendering
3113 2 1- andrewlowell
- 537 posts
- wolfwood
- 4262 posts
andrewlowell
On the Comp ROPs there should be a parameter called “Reload All Files”
Turning that on should cause the COP networks to update.
- andrewlowell
- 537 posts
