I've noticed that in SOPs, the index order of a merge is based on the order in which nodes are connected as inputs. However, in LOPs, the index order actually takes the Scene Graph Tree hierarchical order, which by default is alphabetical. Is this intentional?
An example would be if I had an instancer lop and set the Prototype Index to 'Index', and chose index zero. The assumption would be that the first prim input would be the prim that is instanced. Eg: if my prototype input was a merge node with 3 prims plugged into it, you would assume that the first prim plugged into the merge would be Index 0.
Repro attached in next post.
Question about LOPs Merge index
1852 3 0-
- Hamilton Meathouse
- 209 posts
- オフライン
- 209 posts
- オフライン
- jsmack
- 8173 posts
- オンライン
Hamilton Meathouse
Prims don't have indices, or other implied order. The instancer has no idea how the prototype stage is composed. It could be multiple lops merged, it could be multiple layers referenced in many possible ways, many of which would not result in a well defined prim order. The instancer lop's index is based on alphabetical sorting because there isn't any other implied order. The instancer also allows defining the order explicitly with the name attribute.
The order of inputs to a merge affects layer strength. Think of as the list of files to the sublayer command. Since multiple layers can modify the same prims, this strength order determines which layer 'wins' for a given primitive.
- 209 posts
- オフライン
Thanks Jmack - makes sense. It caught one or two people out (myself included) who were coming from a traditional Houdini background. If you're merging inside an instancer (ie; Sops) and jump up a level to lops, you could be forgiven for assuming merges would have similar behaviour.
Good to know, especially the part about strength ordering!
Edited by Hamilton Meathouse - 2021年10月3日 16:57:34
