How to foreach in SOP, mixing with VEX properly?
   1405   2   0
Hi! I want to run foreach in SOP 5 times, adding some arguments from the arrays defined in VEX. Right now I am trying to
come up with crazy idea like creating 5 empty points, iterating on then, while feeding data I need from the other input point attributes;
Is there more "clean" way to do it, without creating intermediate points for the foreach_begin to loop over?
You can store both arrays as detail attributes and then work on those inside the For Each SOP network. No need to create new points, unless you want to work on each element in parallel.
"You can store both arrays as detail attributes"
Huuh, wonder why I could not make this work... Thanks! Will try again and see, I suspected I was doing that on point level
