Making curve shorter
   1674   2   0
Hi! I have very simple task, but for some reason, its not working, and this drives me crazy.
Basically, I create curve from 2 points. This works.
I want to make it shorter - not working.
Node network itself is quite simple:
Inside "attribwrangle3", get 2 points, then substract them to get normalized direction
Then I simply prepare data to feed into curve node
And finally I can pretty looking curve
Now, if you look at the curve creation code, those lines:
if(reverse > 0)
eachPoint += @pointMoveDirection * -1;
reverse *= -1;
else
eachPoint += @pointMoveDirectionInverse * -1;
reverse *= -1;
they must move end points of curve towards each other and make it shorted. Instead, points are being move in some other direction.
But why? How? I substract P2-P1 and normalize. I have clean line as results. And still.
moves points in weird direction, and there are only 2 points within "connected1" group
probably v@xyz is missing in the vector attribute (write v@xyz and not @xyz). Have you tried carve node, it works on every curve.
thanks!! you are a lifesaver carve node did exactly what I need
