vellum grain leaking whith a second collider!!
   2616   3   2
Hi everybody
Here is a problem I'v been struggling all day without finding a solution.
Y have a vellum grain colliding with a ground geo.... every thing is fine. But when a second deforming collider comes in play and gently pushes the grains, my grains are leaking through the ground....
Here is a sample in a simple scene where I replicated the issue, the one I'm working on is much more complex and much more leaking.
I'v try many settings, none is working
Pleas help me dear fellows
Malik
VELLUM_GRAIN_LEAK.hiplc (513.2 KB)
NAHASSIA
Hi everybody
Malik
vellum needs substeps when you have moving geo. change the vellum solver substeps to 10 and it should work
Edited by mihatsu - 2021年12月28日 16:37:22
VELLUM_GRAIN_LEAK.hiplc (516.4 KB)
or on your /obj/grid1/vell/ground object you can set Collision Detection to Use Volume Collider
since Vellum's default is surface so your SDF wasn't being taken into account
Thanx a lot for your help.
It worked fine specialy the surface / volume collision detection in vellum
