The curve is extruding to the sides
2317
4
0
gluo316
2022年5月11日 5:43
I recently learned Houdini and used the curve node to draw a curve. Then I used the polyextrude node to extrude a curve, but only to one side, but I want the curve to extrude to both sides from its center. What should I do?
Hatchery
2022年5月11日 13:31
id do it like this
Test.hipnc (148.8 KB)
Love Houdini
gluo316
2022年5月12日 0:10
孵化场 id do it like thisHatchery thank you for your reply. This is a good idea. Thank you.
vicvvsh
2022年5月12日 1:21
You can use sweep sop for this task, "Surface Shape" - Ribbon, "Columns" - 2
gluo316
2022年5月12日 23:20
vicvvsh You can use sweep sop for this task, "Surface Shape" - Ribbon, "Columns" - 2Thank you for your reply. It is also a good method and very helpful to me.
