Access material binding attribute in SopModify LOP
   1432   2   0
I'm using a SOP modify to update some UVs and I've got materials assigned to multiple different geo prims, in the sop modify I want to process them based on their assigned material names.
I just can't seem to transfer/promote that attribute/primvar so I can access it inside the SOP modify.
Is there anyway to achieve this?
David.
After a bit more research, I think using usd_attrib in a prim wrangle gets me close, it works for other prim vars but not for material bindings. I feel like I've not got the syntax quite right.
string materials[] = usd_attrib(s@usdpath, s@usdprimpath, "material:binding");
s[]@mat=materials;
スタッフ
You might want to consider using usd_boundmaterialpath instead. Getting the "material:binding" value directly from each prim is only one way that USD allows for binding of materials.
