IntersectionAnalysis: Collected Attributes don't make sens? {[SOLVED]}
   1726   2   0
Hi!
I connected 2 polygonal geos (not curves) to the IntersectionAnalysis sop:
input 0: 428108 primitives
input 1: 24494 primitives
I toggled Input Number and Primitive Number but when I look at the geo Spreadsheet, it says one of the hit from input 0 is primitive number 496294. The problem is I don't even have that many primitives in input 0. How can I get that result?
...is that sop only meant to be used with curves.. ?!
-Olivier
Edited by olivierth - 2023年7月6日 17:31:32
Can't check right now, but I believe intersection analysis expects triangulated geo, and if it's not then it triangulates internally
Therefore the numbers may refer to the triangulated prims
(There is a warning on your node which probably says something along those lines)
So try adding Divide SOP to triangulate before and see if the numbers match
Arg, yes, I forgot to read the warning:
A triangle and curve mesh is required on the input for correct attribute output.A triangle and curve mesh is required on the input for correct attribute output.
I ended up using another method that did not require those attributes.
-Olivier
