i feel like i should be able to find this in the documentation, but i cannot find it anywhere.
I have geometry (with good UVs I think), and a material with texture assigned, but I'm not seeing the texture drawing in the viewports.
Can anyone tell me how to turn this on?
thanks in advance!
display texture in viewport in H9?
4968 8 1- jasonkaehler
- 16 posts
- edward
- 7722 posts
It should just work by default unless you've turned it off in the viewer. You can double check the display options by hitting ‘d’ in the viewport and looking in the Misc tab. Which SHOP are you using? Sometimes, the texture map parameter on the OGL tab isn't set up to reference the regular texture map parameter as well. In that case you need to put in a `chs()` reference to the right parameter.
- jasonkaehler
- 16 posts
okay, so i hit ‘d’ and display textures is on for the viewport.
For the material, i just dragged "Basic Surface' over to see the icon, then added a Color Map. I know it's assigned because when i change the Base Color, i see the color change in the viewport.
As for the SOPs i'm using, here is the network.
Also, FWIW, when I create a Sphere and assign same material, i see no texture in viewport also (they have UV by default, right? If so, this would indicate problem is not with my geometry/UVs?).
I'm running an ancient Nvidia Gforce 7800 GTX, I wonder if that's the problem?
- edward
- 7722 posts
- jasonkaehler
- 16 posts
- shikung444
- 66 posts
- edward
- 7722 posts
- jasonkaehler
- 16 posts
- edward
- 7722 posts
Ah, I had assumed you were using one of the default SHOPs. For custom ones, you need to make sure that you have a OGL Texture Layer (ie. in your basic VOP VEX Surface SHOP) that uses the same file. The viewport only looks at those parameters.
Your second problem is that that rows & columns only works for Mesh and NURBS primitives but you had turned on Output Polygons in the PolyPatch SOP. Turning this off gives the correct uv's. Afterwards, you can convert back to Polygons after the texture SOP if you wish (or need to).
