[MtlX] constant color is broken? H20
   1814   4   0
The native constant working but not the Mtlx
Am I doing something wrong?
Crag brought from /obj with (Scene Import All) with Material Binding 'Stronger...'
Edited by jomaro - 2023年11月27日 13:23:20
Now I have this:
(But working fine with native Houdini constant color)
Edited by jomaro - 2023年11月27日 13:30:45
After connecting the native constant (color) and back to MatlX constant now working OK!
You need to remind it with the native node I guess :/
Ok it seems the MtlX nodes working only when you render.
It's most likely due to using the Karma Material builder instead of the USD Mtlx Builder. The Karma builder allows nodes that are not part of mtlx and so can't map directly to the viewport shader--it requires translation to a usd preview surface. Most nodes won't translate to USD preview surface, such as the mtlx constant node. The native constant node isn't a node at all, it creates an input connection to the material.
