HDK and MSVC 2005
3224 3 1- SpOOkyPaul
- 31 posts
- joelvaneenwyk
- 30 posts
Hi SpOOkyPaul,
Unfortunately, you really do have to use VS2003, because the existing Houdini libaries would not be compatible with your plugin if you used VS2005. You can compile your plugin with VS2005 and run it, but if you try to use any functions in the existing Houdini libraries (which you have to do if you want to get anything done), it will lock.
I'm not sure if SideFX has any plans on upgrading to VS2005 soon, but if/when they do, I'm sure they'll announce it in the changelogs.
–Joel
–Joel
- edward
- 7726 posts
- SpOOkyPaul
- 31 posts
