How do I Install licenses non-graphically?
If you are running a headless server or are having issues using the graphical License Administrator utility hkey, the non-graphical utility sesictrl will allow you to administer the license server through the command line.
To obtain help information about a specific command run: sesictrl --help
If you need help information from the legacy sesictrl interface enter: sesictrl --legacy-help
Examples of using sesictrl:
  • Redeem license entitlements: sesictrl redeem
  • Install generated keystrings: sesictrl install copy-generated-keystring-here
  • Return licenses: sesictrl return-license
  • Generate the license diagnostics: sesictrl diagnostic
  • License usage: sesictrl print-license
To access the program sesictrl, you will need to source the Houdini environment.
  • Start->Search and type "Command Line Tools 21.0".
  • Or, C:/Program Files/Side Effects Software/ Houdini 21.0.x/bin/hcmd.exe
  • Type sesictrl at the prompt to see the available options.
OSX
  • Spotlight search for Houdini Terminal for your specific Houdini version.
  • Applications->Houdini->Current->Utilities->Houdini Terminal 21.0
  • You can also source the Houdini environment in your shell:
    • cd /Applications/Houdini/Houdini21.0.X.XXX/Frameworks/Houdini.framework/Versions/Current/Resources
    • source ./houdini_setup
Linux
  • The sesictrl program is located in /usr/lib/sesi
  • Type ./sesictrl to see the available options
    • cd /opt/hfs21.0
    • source houdini_setup
For more information about sesictrl please refer to www.sidefx.com/docs/houdini/ref/utils/sesictrl.html
