Multi FlipBook
   10759   5   0
Hi everybody
I have a problem. Some help will be much appreciated.
I have two different Houdini opened on the same computer to compute two different playblast simulation
When I launch a flipbook with the first Houdini and at the same time another playblast on the second openend houdini it seems to overwrite the first playblast.
So, is it possible to run another playblast without replacing the one that is already running ??
Thanks a lot !!!
ps: Working on Linux Gnome 3.4.2 - Quadro fx Gc - Xeon cpu -24 Gig Ram
Yes, just type unique flipbook session label.
Waouhhhh
You solve my problem in 10 minutes !!!
Thanks a lot.
thanks!!! C:
The other way to do this is to click the “New Sequence” icon button (upper right corner, looks like a filmstrip) after you've flipbooked the first sequence. The next flipbook will go to a separate sequence in the same mplay session. This way you can easily diff them as well (Ctrl+D), manage them via the sequence list (Alt+L), and playback multiple sequences in synch (View > Layout > 2 Columns). You can do this as much as your mem can support, and remove old sequences via the Sequence List.
Flipbook session label disappeared in 16.5 ( even in 16.0 is gone).
How can we label flipbooks that we keep in Sequence List ?
Michal Tas Maciejewski @ www.vfxtricks.com
