Best practice for aligning Blueprints
   2655   1   1
For modelling realistic military vehicles or vehicles in general I need to setup blueprints as reference images in the background
So far I have figured out the best way would be to use png images with alpha channel and put them into the display options - Background Image (one per view)
Put now i am facing a problem:
I am used to zoom into areas for detailed modelling.
When i zoom in/out, the image stays the same size while only the scene is becoming bigger/smaller.
Blender behaves differently, and zooms reference images same amount as the scene in orthogonal projection. I would prefer this behaviour but have not found the option switch yet.
Aditionally i need the images to match their position, so moving up/left/right/down should also move the image, not only the scene.
Can you please assist oder give any advice?
Your Answer will be highly appreciated
Edited by SRal - Aug. 3, 2016 15:48:13
Thanks for your fast response via Skype, i was told to uncheck “Auto-Place Image”
Issue solved.
Edited by SRal - Aug. 3, 2016 15:51:46
