Hi!
Situation : 2 Indie licenses running on a local network.
When the COPS network is set to render out an 8k image or lower, it works on both machines. However, when it's set to use a 16k image as its base to comp on to, it will only work with Hqueue on the server machine. The other machine will give a “ERROR: The attempted operation failed. Error: Cook error in input : <Node name>”
Edit : it's specifically one file node that reads either an 8k or 16k image.
Anyone any ideas ? Thanks.
[Hqueue - COPS] - 8k and lower is fine on all machines, 16k and up it only renders at server
1826 1 0-
- paleoPixels
- 26 posts
- paleoPixels
- 26 posts
