localisation
3307 4 0-
- anon_user_37409885
- 4189 posts
- CYTE
- 805 posts
- 4189 posts
- ahfx
- 15 posts
This is a topic I have been thinking about. I know people would have to deal with this when rendering on the cloud. So I am curious to know what solutions are out there. I am not familiar with how nuke handles this.
For OTLS you can leverage scan paths.. ie get all of the OTLS in your scene and then place a copy of them into something like $HIP/otls
For all other external references you could use variables in paths. $REMOTE_OR_LOCAL_DRIVE/path/to/cache
Then update $REMOTE_OR_LOCAL_DRIVE as needed. You would have to ensure all paths are prefixed with that variable. It would be easy for someone to place a read node and point it to a cache without knowing about that variable.
The trick I am interested in is knowing what external references exist before loading the scene. Which I suppose you could handle by saving a ‘sidecar’ with your houdini scene every time you save, a text file containing all the external references in your scene. This is a little anoying because its another thing to manage and ensure is up to date/
Then on your farm or remote machine before you load houdini:
Should work, thoughts?
# check the sidecar # copy the external files to the remote machine if they are out of date # update REMOTE_OR_LOCAL_DRIVE to your remote drive root # load your scene and render
- jacob3dbcf42ddcfc4810
