I'm having troubles with houdini again,
it installs perfectly fine and runs fine, but for some reason everytime i start houdini i have to restart hserver and sesientd
is there anything i can do so that i do not have to do this each time??
also can i do away with the source houdini_setup command? is there a file i can put this text in so it will run on start-up/login??
thanx for your time and help
Rikki
Trouble re-starting houdini
11957 3 1-
- --Rikki--
- 9 posts
- stevenong
- 1634 posts
Hi Rikki,
cd /usr/hfs5.5; source houdini_setup; cd
at the end of the file.
This way, every time you start a shell, the Houdini environment will be initialized for you.
I hope the above helps!
Cheers!
steven
--Rikki--I would suggest re-installing the license server from the CD. You will have to login as root.
--Rikki--You can edit the .tcshrc or .cshrc file, depending on which shell you use and add the following:
Cheers!
steven
- --Rikki--
- 9 posts
I have re-installed the license server, but this does not seem to have any effect on the hserver problems,
i added some lines into my .cshrc file to re-load the hserver and set it to the hostname of ‘linux’
this works perfectly if i reboot once uses the license server to ‘linux’, but after multiple reboots it trys to pick up the license server as ‘linux=’
is this a problem with SuSE linux??
would houdini run better on Mandrake or RedHat??
- lucas
- 269 posts
