merge only if node has active display tag
   2119   5   2
I'm merging a bunch of objects, this is the sop path in my object merge node:
/obj/ManualTrees/Tree_A_rndr*/OUT_instances_A
I would like to only merge in the node(s) (Tree_A_rndr*) if the display tag on that geo node is set to active, is this possible?
In the object merge node documentation I saw a tip that states:
"You can use __display_sop__ or __render_sop__ in the path instead of the name of a real surface node name to have Houdini use whatever node has the display flag or render flag."
I don't understand this tip, is it saying you can only use __display_sop__ by itself, so it will consider everything in the entire scene?
No, it's saying you can enter
/obj/ManualTrees/Tree_A_rndr*/__display_sop__
to import whichever node has the display tag in that object. As to what you want to achieve, one way would be having a switch with expression
ch("../tdisplay")
before your OUT null, switching to nothing if your display is off. There are probably cleaner options.
Edited by Tanto - April 18, 2023 11:45:51
Tanto
Thank you for the clarification! That's really good to know.
Tanto
ch("../tdisplay")
That's exactly what I was curious about, how to access the display flag as a parameter, since I couldn't find it anywhere except in the network view.
I tried the switch setup you suggested, but it doesn't seem to work:
https://www.dropbox.com/s/i3fnpzdf0hvnrhq/displayFlag.gif?raw=1 [www.dropbox.com]
My mistake, the parameter was actually ch("../display"), and even then it's not affected by the display flag.
Tanto
Aw yeah, I tried that one too strange
I was also interested in doing this for a project and ended up writing a Python node for it which worked decently enough.
A bit hacky but works alright. Only caveat is sometimes it doesn't update properly when toggling visibility.
You have to turn on "create per primitive-path" and "pack geometry before merging" in the objectmerge sop so that it treats OBJ nodes as a whole and create a visibility attribute on the geometry stream before the Python node.
node = hou.pwd()
geo = node.geometry()
for point in geo.points():
    path = point.attribValue("objname")
    node = hou.node(path)
    parent = node.parent()
    isOn = parent.isDisplayFlagSet()
    point.setAttribValue("isOn", isOn)
merge_visible.hiplc (811.5 KB)
