APEX Ragdoll Interactive Mapping Mode
   4224   5   2
I currently follow a apex tutorial for doing ragdoll animation and everything goes fine until I try to go in interactive mapping mode to map my ragdoll to my rig.
https://www.youtube.com/watch?v=RpNIkx6ADBI [www.youtube.com]
The things I'm trying to do is at time 20m19s. The "M" shortcut cycle through the alignment modes , not going into the "Enter Interactive Mode" as supposed to be. Others shortcut work great ( H , Ctrl + H , G , Ctrl + G )
I get stock to these steps because I'm not be able to go in to this mode.
Greetings,
my apologies! The "M" hotkey has gone through some changes as of late and some of those changes did not make it to the build just yet. We will address this issue today by switching the mapping hotkey to "N" instead. If you can, please download tomorrow's daily build and that should have the fix.
Thank you!
Hi,mapping still dont work on 20.5.323
Edited by Jorge Ivanovich2 - Aug. 12, 2024 19:55:57
Can you please log a bug ? Thank you
mihneas
Greetings,
Thank you!
Hi, I encountered the same problem in build 20.5.478, has the Interactive Mapping Mode input changed somehow? I can't find a solution to this problem, please help!
Mapping your ragdoll character should be done in the APEX Map Character SOP, it's no longer done within the animate state
