Hello. I bought an HDA from a maker on Gumroad. I cannot, for the life of me, get it to install. I've followed many YouTube tutorials, but not one of them has been successful.
I have put it in the Documents/houdini20.5/otls folder.
HOUDINI_OTLSCAN_PATH=C:\Users\admin\Documents\houdini20.5\otls
I've created a directory on a different drive
HOUDINI_OTLSCAN_PATH=E:/_PROJECTS_Video_and_VFX/_Project_Common_Elements/houdini_hdas/otls;&
I'm inclined to think I'm doing something wrong. Is there a particular way the command line should be formatted? What's the syntax?
Could it be the name of the actual file? Is there a particular way that needs to be written? The file extension is currently .hda.
Installing HDAs or Creating Digital Asset Libraries
899 5 1-
- BrianG61
- 7 posts
- mmwizard
- 21 posts
- BrianG61
- 7 posts
mmwizard
What version of Houdini do you run?
If it's Houdini 21 then have to go to C:\Users\yourname\Documents\houdini21.0\otls\
kind regards
I'm using 20.5.684.
This is my home computer, and I haven't created an account other than Admin, so Admin would be my name, I suppose. Also, I swapped the backslashes with forward slashes. Still no luck.
- mmwizard
- 21 posts
- BrianG61
- 7 posts
mmwizard
Strange.
Can you open the hda with Houdini? maybe you get an error with more info.
If you mean, can I open it as if opening a project, no. The error message is "Error: Invalid .hip file header"
I can, however, import the asset into a scene. Somehow, I missed that I could do that. It didn't add it to either of the otl libraries I was trying to create, but at least it imports directly
Edited by BrianG61 - Oct. 28, 2025 14:28:53
- mmwizard
- 21 posts
